Pular para o conteúdo principal
Ajuda
Motorola V3i Teardown
Teardown
Teardown
As desmontagens servem para mostrar o que tem dentro de um/uma device e não devem ser usadas como instruções de procedimento.
Guia contribuído por membro
Um membro impressionante de nossa comunidade fez este guia. Não é gerenciado pela equipe iFixit.
A Motorola V3i it's from the "RAZR" series.
The V3i had an improved camera resolution with 1,3Mpix and a external Memoryslot (MicroSD) for additional storage. Even if it had serveral problems with the keyboard and handling, it's one of the most sold mobilephones in the world.
Passo 1 Motorola V3i Teardown  ¶
A Motorola V3i!
  • A Motorola V3i!
  • Let's see what's inside...
Passo 2  ¶
Let's turn it and take out the battery. Remove these two screws.
Passo 2  ¶
  • Let's turn it and take out the battery.
  • Remove these two screws.
Passo 3  ¶
Now you can easily flip the cover.
Passo 3  ¶
  • Now you can easily flip the cover.
Passo 4  ¶
You need to detach these two plastic lashes from the surounding. Now you can remove this transparent plastic case. Now you can take out the speaker.
Passo 4  ¶
  • You need to detach these two plastic lashes from the surounding.
  • Now you can remove this transparent plastic case.
  • Now you can take out the speaker.
  • The metal thing on the end of the picture is the antenna.
Passo 5  ¶
So, that's the board. Vibra motor.
Passo 5  ¶
  • So, that's the board.
  • Vibra motor.
  • Mini USB.
  • Connector for the antenna.
  • After I took these EMI shields away it looks like this...
Passo 6  ¶
Bluetooth chip by Broadcom. 32Mbit PSRAM by STMicroelectronics.
Passo 6  ¶
  • Bluetooth chip by Broadcom.
  • 32Mbit PSRAM by STMicroelectronics.
  • Baseband Processor (Main Processor) by Freescale (90nm structure).
  • RF Transmitter by RF Micro Devices.
  • Battery controller by Freescale.
  • Quad-Band Transmit Module by RF Micro Devices.
Passo 7  ¶
Remove these 4 rubbers. Then remove the four torx screws.
Passo 7  ¶
  • Remove these 4 rubbers.
  • Then remove the four torx screws.
  • You can easily lose these rubbers. (That's why I have only 3 of them...)
Passo 8  ¶
Filp the device and you can remove the top housing. Remove the three buttons on the side of the device.
Passo 8  ¶
  • Filp the device and you can remove the top housing.
  • Remove the three buttons on the side of the device.
  • Remove the connector to the mainboard...
  • and to the camera.
Passo 9  ¶
Remove the camera by lifting it up.
Passo 9  ¶
  • Remove the camera by lifting it up.
  • That's a 1,3Mpix camera!
Passo 10  ¶
Lift up the speaker. Then, that's a tricky part,remove all the buttons around the screen housing. Caution: They are really thin and they easily break! After you did this tricky part you can lift the top of the phone away.
Passo 10  ¶
  • Lift up the speaker.
  • Then, that's a tricky part,remove all the buttons around the screen housing. Caution: They are really thin and they easily break!
  • After you did this tricky part you can lift the top of the phone away.
Passo 11  ¶
Now lift up the front glass from the top of the device. It's held with adhesives. After you did this it should look like this.
Passo 11  ¶
  • Now lift up the front glass from the top of the device. It's held with adhesives.
  • After you did this it should look like this.
Passo 12  ¶
Around the screen there are some lashes. Detach them to release the screen of the metal housing. Then you can lift the metal housing up.
Passo 12  ¶
  • Around the screen there are some lashes. Detach them to release the screen of the metal housing.
  • Then you can lift the metal housing up.
Passo 13  ¶
The metal housing is very fragile! an ATI Imageon chip! It's a mulitmedia co-processor, it is used for record video and mobile gaming. It support up to a 2Mpix camera.
Passo 13  ¶
  • The metal housing is very fragile!
  • an ATI Imageon chip! It's a mulitmedia co-processor, it is used for record video and mobile gaming. It support up to a 2Mpix camera.
Passo 14  ¶
Again there's a small lash on the botton of the front screen housing. After that you can remove the front screen with the PCB.
Passo 14  ¶
  • Again there's a small lash on the botton of the front screen housing.
  • After that you can remove the front screen with the PCB.
Passo 15  ¶
The front screen.
Passo 15  ¶
  • The front screen.
  • Yes, my front screen has some dead pixels. (They are pink?!)
Passo 16  ¶
Thank you for reading my Teardown:)
Passo 16  ¶
  • Thank you for reading my Teardown:)
