Pular para o conteúdo principal
Ajuda
Motorola Droid 2 Teardown
Teardown
Teardown
As desmontagens servem para mostrar o que tem dentro de um/uma device e não devem ser usadas como instruções de procedimento.
Is this the Droid we're looking for? Why yes! Yes it is! We've acquired the latest smartphone on the market, the Motorola Droid 2. Join us as we break down this Droid into its most basic components.
Passo 1 Motorola Droid 2 Teardown  ¶
The Droid 2 features: Texas Instruments OMAP (Open Multimedia Application Platform) 1GHz processor with dedicated GPU. 8 GB internal storage space.
  • The Droid 2 features:
  • Texas Instruments OMAP (Open Multimedia Application Platform) 1GHz processor with dedicated GPU.
  • 8 GB internal storage space.
  • 5 MP camera with auto focus.
  • 3.7" WVGA display
  • Android 2.2 OS (Froyo)
  • The Motorola Droid 2 measures 4.58" x 2.36" x 0.54" and weighs in at 5.96 oz.
  • Taking a page from Apple, the Droid 2's nifty and compact packaging is a sight to be admired.
Passo 2  ¶
Side-to-side comparison of the Droid (left) and Droid 2 (right). If you have a broken original Droid, check out our Droid repair manuals before forking out the cash for the new Droid 2!
Passo 2  ¶
  • Side-to-side comparison of the Droid (left) and Droid 2 (right).
  • If you have a broken original Droid, check out our Droid repair manuals before forking out the cash for the new Droid 2!
  • The new Droid 2 looks sleeker than its predecessor with the dark blue finish and slight modifications to the case.
  • Rather than having a front panel with a sharp offset lip like the Droid, the Droid 2's front panel features a smooth transition to make it more pocket friendly.
Passo 3  ¶
The top of the line Apple iPhone 4 up against the new Droid 2 equipped with Android 2.2 Froyo. Unsurprisingly, the iPhone 4 is much thinner. Thickness is the price you must pay for a keyboard with actual buttons.
Passo 3  ¶
  • The top of the line Apple iPhone 4 up against the new Droid 2 equipped with Android 2.2 Froyo.
  • Unsurprisingly, the iPhone 4 is much thinner. Thickness is the price you must pay for a keyboard with actual buttons.
Passo 4  ¶
The battery cover comes off without much fuss, and we're on our way to tearing this phone apart! The battery cover comes off without much fuss, and we're on our way to tearing this phone apart!
Passo 4  ¶
  • The battery cover comes off without much fuss, and we're on our way to tearing this phone apart!
Passo 5  ¶
Unlike the iPhone 4 with its "Authorized Service Provider Only" pull tab, the Droid 2 has a helpful note stating "battery removal here."  Thanks, Motorola. Along the top side of the battery is one of the two visible moisture damage markers. The other is found to the left of the microSD card.
Passo 5  ¶
  • Unlike the iPhone 4 with its "Authorized Service Provider Only" pull tab, the Droid 2 has a helpful note stating "battery removal here." Thanks, Motorola.
  • Along the top side of the battery is one of the two visible moisture damage markers. The other is found to the left of the microSD card.
  • The Droid 2 has a 3.7V, 1390 mAh Li-Ion Polymer battery, providing up to 9.5 hours of talk time.
  • This is the exact same battery used in the Droid, and only slightly smaller than the 1420 mAh battery found in the iPhone 4.
Passo 6  ¶
The Droid 2 comes pre-installed with an 8GB microSD memory card that can be easily slid out of its socket.
Passo 6  ¶
  • The Droid 2 comes pre-installed with an 8GB microSD memory card that can be easily slid out of its socket.
Passo 7  ¶
Every screw holding the Droid 2 together is cleverly hidden behind the many covers stuck to the rear of the device. Every screw holding the Droid 2 together is cleverly hidden behind the many covers stuck to the rear of the device. Every screw holding the Droid 2 together is cleverly hidden behind the many covers stuck to the rear of the device.
Passo 7  ¶
  • Every screw holding the Droid 2 together is cleverly hidden behind the many covers stuck to the rear of the device.
Passo 8  ¶
A screw here, a screw there, and we're almost in! After prying the rear case off, we finally get to see what makes the Droid 2 tick. After prying the rear case off, we finally get to see what makes the Droid 2 tick.
Passo 8  ¶
  • A screw here, a screw there, and we're almost in!
  • After prying the rear case off, we finally get to see what makes the Droid 2 tick.
Passo 9  ¶
Five pressure contacts on the headphone jack press against the gold pads attached to the camera board to exchange data.
Passo 9  ¶
  • Five pressure contacts on the headphone jack press against the gold pads attached to the camera board to exchange data.
Passo 10  ¶
The speaker is held in place by the pressure of the two case halves when they are locked together, so at this point it can be simply lifted out of the Droid 2. The speaker looks to be the same model as the one in the original Droid. The gold sticker applied to the speaker housing is a cleverly placed antenna.
Passo 10  ¶
  • The speaker is held in place by the pressure of the two case halves when they are locked together, so at this point it can be simply lifted out of the Droid 2.
  • The speaker looks to be the same model as the one in the original Droid.
  • The gold sticker applied to the speaker housing is a cleverly placed antenna.
Passo 11  ¶
This Droid 2 opening tool gets a workout disconnecting the antenna, display data ribbon cable, and power/volume button ribbon cable from the motherboard. This Droid 2 opening tool gets a workout disconnecting the antenna, display data ribbon cable, and power/volume button ribbon cable from the motherboard. This Droid 2 opening tool gets a workout disconnecting the antenna, display data ribbon cable, and power/volume button ribbon cable from the motherboard.
Passo 11  ¶
  • This Droid 2 opening tool gets a workout disconnecting the antenna, display data ribbon cable, and power/volume button ribbon cable from the motherboard.
Passo 12  ¶
After removing the screws securing the motherboard to the phone and disconnecting the keypad ribbon cable on the opposite side, the motherboard is finally free from Droid 2. After removing the screws securing the motherboard to the phone and disconnecting the keypad ribbon cable on the opposite side, the motherboard is finally free from Droid 2.
Passo 12  ¶
  • After removing the screws securing the motherboard to the phone and disconnecting the keypad ribbon cable on the opposite side, the motherboard is finally free from Droid 2.
Passo 13  ¶
The motherboard assembly stands alone in all its glory.
Passo 13  ¶
  • The motherboard assembly stands alone in all its glory.
  • The camera board is actually a separate circuit board that can be easily removed from the motherboard.
  • Awww man, all those chip covers are soldered down. You think that's going to stop us?
Passo 14  ¶
Big players on the front of the motherboard include: Qualcomm QSC6085 CDMA Processor
Passo 14  ¶
  • Big players on the front of the motherboard include:
  • Qualcomm QSC6085 CDMA Processor
  • Elpida K4332C1PD-50-F - 512MB Mobile DDR3 RAM for the OMAP3630.
  • TI OMAP 3630 is secreted underneath the Elpida package (thanks Chipworks!).
  • Numonyx NANDA9R4N4 NAND/DRAM package that supports the QSC6085 CDMA processor. DRAM is most likely for the camera processor, while the NAND may be holding software for functions like the GPS.
  • AKM 8973N 019A Compass
  • S202 7927 microphone
  • This secondary microphone picks up background noise and helps cancel it for clearer calls.
Passo 15  ¶
Back of motherboard: SanDisk SDIN4C2 8 GB NAND flash
Passo 15  ¶
  • Back of motherboard:
  • SanDisk SDIN4C2 8 GB NAND flash
  • TriQuint TQM613029 CDMA PA-Duplexer Module
  • Avago FEM-7758 CDMA Front End Module
  • TI 51001582002 Power management IC
  • TI WL1271B WLAN Bluetooth/FM chip
  • ST G 40N 025
  • Unidentified OST chip
Passo 16  ¶
The Droid 2's 5 MP rear-facing camera with dual-LED flash supports DVD-quality video recording at 6 more FPS than the original Droid - 30 fps vs. 24 fps.
Passo 16  ¶
  • The Droid 2's 5 MP rear-facing camera with dual-LED flash supports DVD-quality video recording at 6 more FPS than the original Droid - 30 fps vs. 24 fps.
  • Yet the camera board doesn't look all too different than the one equipped on the original Droid.
Passo 17  ¶
After disconnecting an antenna connector and a ribbon cable leading to the vibrator motor & control buttons, the small board at the bottom of the Droid 2 can be removed. Between all the web-browsing and texting, when you make the occasional call on your Droid 2, this microphone lets you be heard. Between all the web-browsing and texting, when you make the occasional call on your Droid 2, this microphone lets you be heard.
Passo 17  ¶
  • After disconnecting an antenna connector and a ribbon cable leading to the vibrator motor & control buttons, the small board at the bottom of the Droid 2 can be removed.
  • Between all the web-browsing and texting, when you make the occasional call on your Droid 2, this microphone lets you be heard.
Passo 18  ¶
At this point, the black plastic rim can be lifted off the Droid 2. We've thoroughly torn the body of the phone down, so we've turned our attention to the sliding display. A few screws later and the display is open, giving us a first glimpse at the backside of the LCD.
Passo 18  ¶
  • At this point, the black plastic rim can be lifted off the Droid 2.
  • We've thoroughly torn the body of the phone down, so we've turned our attention to the sliding display.
  • A few screws later and the display is open, giving us a first glimpse at the backside of the LCD.
Passo 19  ¶
After disconnecting the digitizer ribbon cable and lifting out the earpiece, the front panel can be separated from the rest of the phone. After disconnecting the digitizer ribbon cable and lifting out the earpiece, the front panel can be separated from the rest of the phone.
Passo 19  ¶
  • After disconnecting the digitizer ribbon cable and lifting out the earpiece, the front panel can be separated from the rest of the phone.
Passo 20  ¶
The LCD can be removed from the keyboard assembly after disconnecting the display data cable. The Droid 2 uses the same  3.7 inch, Full WVGA, 854x480 TFT LCD as the original Droid.
Passo 20  ¶
  • The LCD can be removed from the keyboard assembly after disconnecting the display data cable.
  • The Droid 2 uses the same 3.7 inch, Full WVGA, 854x480 TFT LCD as the original Droid.
Passo 21  ¶
After de-routing the ribbon cable through the slider mechanism, the keyboard can be easily removed from the back of the slider bracket. The second picture shows both Droid keyboards, with the Droid 2 obviously being on top.
Passo 21  ¶
  • After de-routing the ribbon cable through the slider mechanism, the keyboard can be easily removed from the back of the slider bracket.
  • The second picture shows both Droid keyboards, with the Droid 2 obviously being on top.
  • A large D-pad panel was ditched for individual direction keys, a new record button was added, and the enter button was enlarged to more resemble a traditional keyboard.
Passo 22  ¶
Are you wondering if the Droid 2 has the capability to reassemble itself? So are we...in the meantime, here's a before snapshot of all the components. As soon as the Droid 2 reassembles itself, we'll have the after shot.
Passo 22  ¶
  • Are you wondering if the Droid 2 has the capability to reassemble itself? So are we...in the meantime, here's a before snapshot of all the components. As soon as the Droid 2 reassembles itself, we'll have the after shot.
  • Thanks for joining us today during this exciting teardown.
