Pular para o conteúdo principal
Ajuda
Nintendo Wii Motherboard Cover Replacement
Pré-requisito somente
Por favor, note que este guia é apenas um pré-requisito para outros guias.
Passo 1 Motherboard Cover  ¶
Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
  • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
  • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
Passo 2  ¶
Remove the two 10 mm Phillips screws securing the fan to the fan shroud. Remove the fan from the Wii.
Passo 2  ¶
  • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
  • Remove the fan from the Wii.
Passo 3  ¶
Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board. Lift the Wi-Fi antenna out of the fan shroud.
Passo 3  ¶
  • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
  • Lift the Wi-Fi antenna out of the fan shroud.
Passo 4  ¶
Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
Passo 4  ¶
  • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
Passo 5  ¶
Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
Passo 5  ¶
  • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
Passo 6  ¶
Carefully de-route both antennas from the frame of the Wii and lay them aside.
Passo 6  ¶
  • Carefully de-route both antennas from the frame of the Wii and lay them aside.
Passo 7  ¶
Remove the three 10 mm Phillips screws securing the fan shroud to the Wii. Lift the fan shroud off the heat sink and remove it from the Wii.
Passo 7  ¶
  • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
  • Lift the fan shroud off the heat sink and remove it from the Wii.
Passo 8  ¶
Remove the following six screws securing the EMI fingers to the bottom panel: Four 7 mm Phillips screws Two 11.3 mm Phillips screws
Passo 8  ¶
  • Remove the following six screws securing the EMI fingers to the bottom panel:
  • Four 7 mm Phillips screws
  • Two 11.3 mm Phillips screws
  • Remove both sets of EMI fingers from the Wii.
Passo 9  ¶
Remove the following three screws: One 7 mm Phillips screw
Passo 9  ¶
  • Remove the following three screws:
  • One 7 mm Phillips screw
  • Two 10 mm Phillips screws
  • Lift the bracket out of the Wii.
Passo 10  ¶
Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii. Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild. Remove the bracket from the Wii.
Passo 10  ¶
  • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
  • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
  • Remove the bracket from the Wii.
  • Be sure not to lose the small square nut loosely held by the black plastic bracket.
Passo 11  ¶
Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
Passo 11  ¶
  • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
Passo 12  ¶
Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
Passo 12  ¶
  • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
