Pular para o conteúdo principal
Ajuda
MacBook Pro 17" Unibody Optical Drive Replacement
Replace a burned-out optical drive on your MacBook Pro 17" Unibody.
Use this guide to replace your MacBook Pro's optical drive. The Bluetooth board and optical drive cable are not included with a new optical drive.
Passo 1 Optical Drive  ¶
Grab the optical drive cable by its connector and pull it away from the body of the hard drive. Pulling on anything but the connector may damage the optical drive cable. Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
  • Grab the optical drive cable by its connector and pull it away from the body of the hard drive.
  • Pulling on anything but the connector may damage the optical drive cable.
  • Remove the two black Phillips #0 screws securing the small metal mounting bracket. Transfer this bracket to your new optical drive or hard drive enclosure.
Passo 2  ¶
Remove the two 2.2 mm Phillips screws securing the Bluetooth board to the side of the optical drive.
Passo 2  ¶
  • Remove the two 2.2 mm Phillips screws securing the Bluetooth board to the side of the optical drive.
Passo 3  ¶
Remove the Bluetooth board from the optical drive.
Passo 3  ¶
  • Remove the Bluetooth board from the optical drive.
  • Optical drive remains.
