Pular para o conteúdo principal
Ajuda
Xbox 360 Dual Fans Replacement
Dual fans replacement.
  • Autor: Walter Galan
  • Tempo estimado: 40 minutos - 1 hora
  • Dificuldade: Moderado
Keep your xbox running at its optimal temperature by replacing the dual fan assembly.
Seções
Passo 1 Dual Fans  ¶
While lifting the metal chassis strip above the dual fans, pull the fans toward the center of the motherboard. Do not completely remove the dual fan assembly yet. Its cable is still attached to the motherboard.
Passo 1 Dual Fans  ¶
  • While lifting the metal chassis strip above the dual fans, pull the fans toward the center of the motherboard.
  • Do not completely remove the dual fan assembly yet. Its cable is still attached to the motherboard.
Passo 2  ¶
Lift the dual fan connector straight up from its socket on the motherboard.
Passo 2  ¶
  • Lift the dual fan connector straight up from its socket on the motherboard.
  • Some fan connectors have a locking tab. If yours has a locking tab, be sure to depress it while disconnecting the fan from the motherboard.
  • Remove the dual fan assembly from the console.
