Pular para o conteúdo principal
Ajuda
Xbox 360 Lower Case Replacement
Lower Case replacement.
Replace a scratched or worn-out lower case.
Seções
Passo 1 Lower Case  ¶
Stand the console vertically with the top edge facing down.
  • Stand the console vertically with the top edge facing down.
  • Carefully peel the warranty sticker off the console.
Passo 2  ¶
The upper and lower cases are attached via several latches, located in the front and back of the console. These latches must be disengaged to separate the upper case from the console. Use the flat end of a spudger to release the following latches: Above the front-facing USB ports.
Passo 2  ¶
  • The upper and lower cases are attached via several latches, located in the front and back of the console. These latches must be disengaged to separate the upper case from the console.
  • Use the flat end of a spudger to release the following latches:
  • Above the front-facing USB ports.
  • Beneath the front-facing USB ports.
  • Above the Memory Unit slots.
Passo 3  ¶
Insert the flat end of a spudger and pry upwards to release the last remaining latch located above the eject button.
Passo 3  ¶
  • Insert the flat end of a spudger and pry upwards to release the last remaining latch located above the eject button.
Passo 4  ¶
Slightly lift the front portion of the lower case to ensure that the latches in the front have been completely released.
Passo 4  ¶
  • Slightly lift the front portion of the lower case to ensure that the latches in the front have been completely released.
Passo 5  ¶
The upper and lower cases are held together by seven release latches located on the back of the console. Their locations are highlighted in red. The upper and lower cases are held together by seven release latches located on the back of the console. Their locations are highlighted in red.
Passo 5  ¶
  • The upper and lower cases are held together by seven release latches located on the back of the console. Their locations are highlighted in red.
Passo 6  ¶
Press the Xbox 360 opening tool down into the clips securing the lower case to the upper case near the I/O ports. While pressing down on the tool, push the lower and upper cases apart to separate the retaining clips. While pressing down on the tool, push the lower and upper cases apart to separate the retaining clips.
Passo 6  ¶
  • Press the Xbox 360 opening tool down into the clips securing the lower case to the upper case near the I/O ports.
  • While pressing down on the tool, push the lower and upper cases apart to separate the retaining clips.
Passo 7  ¶
While pushing the upper and lower cases apart, use the tip of a spudger or the finger of an Xbox 360 opening tool to push the long clip highlighted in red toward the center of the 360. The clip should release, leaving the clips near the power connector as the only thing holding the upper and lower cases together.
Passo 7  ¶
  • While pushing the upper and lower cases apart, use the tip of a spudger or the finger of an Xbox 360 opening tool to push the long clip highlighted in red toward the center of the 360.
  • The clip should release, leaving the clips near the power connector as the only thing holding the upper and lower cases together.
Passo 8  ¶
Press the Xbox 360 opening tool down into the two remaining clips near the power connector.
Passo 8  ¶
  • Press the Xbox 360 opening tool down into the two remaining clips near the power connector.
  • Push the upper and lower cases apart to fully release the retaining clips.
Passo 9  ¶
Orient the console so that the front portion is facing downwards.
Passo 9  ¶
  • Orient the console so that the front portion is facing downwards.
  • Grasp the back portion of the lower case and lift it upwards to separate it from the console.
  • Be careful not to excessively bend the lower case near the power plug, as it can crack easily.
