Pular para o conteúdo principal
Ajuda
PlayStation 3 Slim Top Cover Replacement
Remove the top cover to access your PlayStation 3 Slim's internals.
  • Autor: Andrew Bookholt
  • Tempo estimado: 5 - 15 minutos
  • Dificuldade: Moderado
Use this guide to remove the plastic top cover.
Passo 1 Top Cover  ¶
Turn the PS3 over and lay it on its backside.
Passo 1 Top Cover  ¶
  • Turn the PS3 over and lay it on its backside.
  • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
  • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
Passo 2  ¶
Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case. Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
Passo 2  ¶
  • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
Passo 3  ¶
Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
Passo 3  ¶
  • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
Passo 4  ¶
Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
Passo 4  ¶
  • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
Passo 5  ¶
Lift the top cover from its rear edge and rotate it toward the front of the PS3. Lift the top cover off the PS3.
Passo 5  ¶
  • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
  • Lift the top cover off the PS3.
