Pular para o conteúdo principal
Ajuda
Mac mini Mid 2010 Speaker Replacement
Replace a blown-out speaker.
Use this guide to replace your mini's speaker. Replacing the speaker requires removal of the logic board.
Seções
Ferramentas
Passo 1 Speaker  ¶
Remove the following two screws securing the speaker to the logic board assembly:
Passo 1 Speaker  ¶
  • Remove the following two screws securing the speaker to the logic board assembly:
  • One 4.2 mm T6 Torx
  • One 3.7 mm T6 Torx
Passo 2  ¶
Carefully lift the speaker wires upward to lift the speaker connector up and out of its socket on the logic board.
Passo 2  ¶
  • Carefully lift the speaker wires upward to lift the speaker connector up and out of its socket on the logic board.
