Pular para o conteúdo principal
Ajuda
iPhone 4 Display Assembly Replacement
Pré-requisito somente
Por favor, note que este guia é apenas um pré-requisito para outros guias.
Replace the display assembly in your iPhone 4.
  • Autor: Walter Galan
  • Tempo estimado: 1 hora
  • Dificuldade: Difícil
This is an outdated version of our iPhone 4 Display Assembly Replacement guide. Please click here for the new version of this guide.
Ferramentas (continuação)
Partes relevantes
Passo 1 Display Assembly  ¶
Remove the following two screws securing the vibrator to the inner frame: One 6 mm Phillips
  • Remove the following two screws securing the vibrator to the inner frame:
  • One 6 mm Phillips
  • One 1.4 mm Phillips
  • Remove the vibrator from the iPhone.
Passo 2  ¶
Remove the 1.5 mm Phillips screw securing the front panel near the headphone jack.
Passo 2  ¶
  • Remove the 1.5 mm Phillips screw securing the front panel near the headphone jack.
Passo 3  ¶
Remove the three large-headed 1.5 mm Phillips screws along the volume button side of the iPhone.
Passo 3  ¶
  • Remove the three large-headed 1.5 mm Phillips screws along the volume button side of the iPhone.
  • Keep track of the washers under each of the screws.
  • Tip: It can be tricky, but it is also possible to just loosen the large-headed 1.5 mm Phillips screws slightly, without having to remove and replace the screw-and-washer set.
Passo 4  ¶
Remove the 1.5 mm Phillips screw near the lower microphone.
Passo 4  ¶
  • Remove the 1.5 mm Phillips screw near the lower microphone.
Passo 5  ¶
Remove the 1.5 mm Phillips screw near the dock connector ribbon cable.
Passo 5  ¶
  • Remove the 1.5 mm Phillips screw near the dock connector ribbon cable.
Passo 6  ¶
Remove the three large-headed 1.5 mm Phillips screws along the SIM card side of the iPhone.
Passo 6  ¶
  • Remove the three large-headed 1.5 mm Phillips screws along the SIM card side of the iPhone.
  • Remove the small-headed 1.5 mm Phillips screw near the rear camera (previously removed).
Passo 7  ¶
Carefully insert the edge of an iPod opening tool between the rubber bezel around the front glass panel and the steel inner frame. Do not attempt to insert the tool between the glass and the rubber bezel.
Passo 7  ¶
  • Carefully insert the edge of an iPod opening tool between the rubber bezel around the front glass panel and the steel inner frame.
  • Do not attempt to insert the tool between the glass and the rubber bezel.
  • Carefully pry the upper edge of the front panel assembly away from the steel inner frame.
Passo 8  ¶
Slowly and gently lift the top edge of the front panel assembly away from the steel inner frame. Continue to rotate the front panel assembly away from the steel inner frame until it slowly begins to peel off the adhesive applied below the home button area.
Passo 8  ¶
  • Slowly and gently lift the top edge of the front panel assembly away from the steel inner frame.
  • Continue to rotate the front panel assembly away from the steel inner frame until it slowly begins to peel off the adhesive applied below the home button area.
  • It may be easiest to insert a spudger at the top and work it around the edges, spreading gently as you go.
  • Carefully pull the lower edge of the front panel assembly away from the steel inner frame.
  • Be careful, if the home button sticks to the front panel you may tear the home button cable.
  • Do not pull the front glass completely away from the frame. Doing so may result In damage to the digitizer cable.
  • If the glass is cracked (which it probably is since you're replacing it) removing the panel is likely to cause it to bend, kicking off small shards of glass. Before you do this step, cover the front with clear tape, then perform the actual removal over a trash can. Protective eyewear would also be prudent.
Passo 9  ¶
De-route the digitizer and LCD cables through the steel inner frame, and remove the display from the iPhone. When reinstalling the display, carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the steel frame. This photo shows the display assembly being installed incorrectly, with a fold in the digitizer cable. When the front panel has been correctly installed, both the LCD and digitizer cables should be immediately next to one another and should be the same length, as shown in the second photo.
Passo 9  ¶
  • De-route the digitizer and LCD cables through the steel inner frame, and remove the display from the iPhone.
  • When reinstalling the display, carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the steel frame. This photo shows the display assembly being installed incorrectly, with a fold in the digitizer cable.
  • When the front panel has been correctly installed, both the LCD and digitizer cables should be immediately next to one another and should be the same length, as shown in the second photo.
  • If the digitizer cable has not been installed correctly, it will not reach its socket on the logic board. Do not attempt to pull it through by force, or it will tear. Remove the display assembly, straighten the cable, and feed it through to its full length, as shown.
  • During reassembly, do not touch the metallic area at the base of the LCD data cable, as this can cause problems with the LCD. If you do touch it accidentally, clean it gently with an alcohol wipe before continuing.
