Pular para o conteúdo principal
Ajuda
MacBook Core Duo Inverter Replacement
Replace a blown-out display inverter to restore your MacBook Core Duo's display backlight.
  • Autor: iRobot
  • Tempo estimado: 1 - 3 horas
  • Dificuldade: Difícil
Screen have no backlight? Replace the inverter.
Seções
Passo 1 Inverter  ¶
Slightly lift the newly-revealed inverter board out of its housing and disconnect the black inverter cable from the left end of the board. Slightly lift the newly-revealed inverter board out of its housing and disconnect the black inverter cable from the left end of the board.
Passo 1 Inverter  ¶
  • Slightly lift the newly-revealed inverter board out of its housing and disconnect the black inverter cable from the left end of the board.
Passo 2  ¶
Disconnect the white inverter cable from the right end of the inverter board. Disconnect the white inverter cable from the right end of the inverter board.
Passo 2  ¶
  • Disconnect the white inverter cable from the right end of the inverter board.
Passo 3  ¶
Remove the inverter board from the display.
Passo 3  ¶
  • Remove the inverter board from the display.
