Pular para o conteúdo principal
Ajuda
Motorola Droid LCD Replacement
Replace your broken LCD to bring new life to your dying Droid.
Seções
Passo 1 LCD  ¶
Slide the phone open. While feeding the display ribbon cable through the slot in the metal keypad backing, slowly continue to slide the phone open past its normal allowed point.
Passo 1 LCD  ¶
  • Slide the phone open.
  • While feeding the display ribbon cable through the slot in the metal keypad backing, slowly continue to slide the phone open past its normal allowed point.
  • Continue feeding the display ribbon cable through and sliding the phone until the LCD assembly is separated from the keypad.
Passo 2  ¶
Lift the back cover off the display assembly, feeding the ribbon cable through the slit as you go.
Passo 2  ¶
  • Lift the back cover off the display assembly, feeding the ribbon cable through the slit as you go.
Passo 3  ¶
Peel away the black tape to reveal the display data cable connector.
Passo 3  ¶
  • Peel away the black tape to reveal the display data cable connector.
Passo 4  ¶
Use an iPod opening tool or fingernail to flip up the black lever on the ZIF connector. Pull the orange display data cable from the ZIF connector.
Passo 4  ¶
  • Use an iPod opening tool or fingernail to flip up the black lever on the ZIF connector.
  • Pull the orange display data cable from the ZIF connector.
Passo 5  ¶
Peel the display ribbon cable from the back of the LCD. The ribbon cable is attached with adhesive, so work slowly to avoid damaging it. Remove the display ribbon from the back of the LCD.
Passo 5  ¶
  • Peel the display ribbon cable from the back of the LCD. The ribbon cable is attached with adhesive, so work slowly to avoid damaging it.
  • Remove the display ribbon from the back of the LCD.
