Pular para o conteúdo principal
Ajuda
IBM ThinkPad T42 RAM Replacement
Pré-requisitos ausentes
Este guia está faltando informações sobre como começar. Faça um guia de início!
Faltou uma etapa
Faltou uma etapa
Ops! Este guia está faltando alguns passos importantes.
  • Autor: Kevin Rehm
  • Tempo estimado: 5 minutos
  • Dificuldade: Muito fácil
ThinkPad accepts PPC2700 chips up to 2 GB.
Seções
Ferramentas
Passo 1 RAM  ¶
Unscrew the pictured screwed holding the memory cover in place.
Passo 1 RAM  ¶
  • Unscrew the pictured screwed holding the memory cover in place.
Passo 2  ¶
Pry the cover open carefully (flathead screwdriver might help)
Passo 2  ¶
  • Pry the cover open carefully (flathead screwdriver might help)
  • To remove the RAM memory stick, push both metal pieces holding it in place outwards, and the stick will pop up.
  • Pull the stick out carefully.
  • In order to replace the other stick, refer to the keyboard replacement tutorial. The other SODIMM is easily accessible with the keyboard removed.
