Pular para o conteúdo principal
Ajuda
MacBook Core Duo Left I/O Frame Replacement
MacBook Core Duo left I/O frame replacement.
  • Autor: iRobot
  • Dificuldade: Moderado
Use this guide to replace the frame over the ports on the left side of your MacBook Core Duo.
Seções
Passo 1 Left I/O Frame  ¶
Disconnect the MagSafe board cable from the logic board.
  • Disconnect the MagSafe board cable from the logic board.
Passo 2  ¶
Remove the single Phillips screw securing the left speaker to the lower case.
Passo 2  ¶
  • Remove the single Phillips screw securing the left speaker to the lower case.
  • Lift the left speaker out of its housing and set it to the side.
Passo 3  ¶
Remove the following 3 screws:
Passo 3  ¶
  • Remove the following 3 screws:
  • Two 7.5 mm Phillips from either end of the left I/O frame.
  • One 9 mm Phillips from the middle of the left I/O frame.
  • Remove the small black plastic spacer at the bottom of the left I/O frame.
Passo 4  ¶
Lift the left I/O frame up and out of the computer. Pay attention to the thin metal EMI fingers, as they may catch as you remove the left I/O frame.
Passo 4  ¶
  • Lift the left I/O frame up and out of the computer. Pay attention to the thin metal EMI fingers, as they may catch as you remove the left I/O frame.
