Pular para o conteúdo principal
Ajuda
Canon PowerShot SD870 IS Shutter Release Button Replacement
Replace the shutter release button.
  • Autor: Sam
  • Tempo estimado: 5 - 10 minutos
  • Dificuldade: Muito fácil
Use this repair guide to remove the faulty release button from your Canon PowerShot SD870 IS.
Partes relevantes
Passo 1 Shutter Release Button  ¶
With the case and LCD screen removed, you are ready to remove the release button. Begin by using the Philips #00 screwdriver to remove two silver 0.159in screws on the top and front of the camera.
  • With the case and LCD screen removed, you are ready to remove the release button.
  • Begin by using the Philips #00 screwdriver to remove two silver 0.159in screws on the top and front of the camera.
Passo 2  ¶
The top plastic piece holding the release button should be held on only by a red-and-black wire connector to the logic board.
Passo 2  ¶
  • The top plastic piece holding the release button should be held on only by a red-and-black wire connector to the logic board.
  • Remove the connector from the logic board and detach the release button housing from the camera.
Passo 3  ¶
With the plastic housing for the release button removed from the camera, use the Philips #00 screwdriver to remove two silver  0.090in screws. The release button can now be removed and fixed or replaced.
Passo 3  ¶
  • With the plastic housing for the release button removed from the camera, use the Philips #00 screwdriver to remove two silver 0.090in screws.
  • The release button can now be removed and fixed or replaced.
