Pular para o conteúdo principal
Ajuda
Mac mini (PowerPC) Modem Replacement
  • Autor: iRobot
  • Dificuldade: Moderado
56k internal modem, standard on all models.
Passo 1 Modem  ¶
Remove the two silver Phillips screws from the corners of the modem board.
Passo 1 Modem  ¶
  • Remove the two silver Phillips screws from the corners of the modem board.
Passo 2  ¶
Pull the modem up from its connector. If it sticks, just wiggle it back and forth a bit as you pull up.
Passo 2  ¶
  • Pull the modem up from its connector. If it sticks, just wiggle it back and forth a bit as you pull up.
Passo 3  ¶
Disconnect the RJ-11 cable from the back of the modem.
Passo 3  ¶
  • Disconnect the RJ-11 cable from the back of the modem.
