Pular para o conteúdo principal
Ajuda
Técnica: iOpener Heating
Pré-requisito somente
Por favor, note que este guia é apenas um pré-requisito para outros guias.
Prerequisite guide to be used by any guide requiring an iOpener. Also prerequisite to the generic iOpener guide.
Ferramentas
Passo 1 iOpener Heating  ¶
We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
  • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
  • Place the iOpener in the center of the microwave.
  • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
Passo 2  ¶
Heat the iOpener for thirty seconds.
Passo 2  ¶
  • Heat the iOpener for thirty seconds.
  • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
  • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
  • Never touch the iOpener if it appears swollen.
  • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
Passo 3  ¶
Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
Passo 3  ¶
  • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
  • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
