Pular para o conteúdo principal
Ajuda
Disassembling KDDI Kyocera A5521K Faceplate
Acidente de Marcação
Este guia precisa de melhores marcações. Ajude corrigindo ou fazendo algumas marcações.
These instructions will demonstrate how to remove the faceplate from the KDDI Kyocera A5521K.
Passo 1 Faceplate  ¶
Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone. Beneath the covers are screws. Beneath the covers are screws.
Passo 1 Faceplate  ¶
  • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
  • Beneath the covers are screws.
Passo 2  ¶
Remove the screws using a Y0 screwdriver.
Passo 2  ¶
  • Remove the screws using a Y0 screwdriver.
Passo 3  ¶
Use the iPod pry tool to remove the outer screen. Two screws are now visible. Be careful not to crack the screen upon removal.  It is adhered strongly to the phone.
Passo 3  ¶
  • Use the iPod pry tool to remove the outer screen.
  • Two screws are now visible.
  • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
Passo 4  ¶
Use the Y0 screwdriver to remove the screws.
Passo 4  ¶
  • Use the Y0 screwdriver to remove the screws.
Passo 5  ¶
Use the iPod pry tool to loosen the faceplate from the phone. Slide the pry tool along the entire crease of the faceplate to completely detach it.
Passo 5  ¶
  • Use the iPod pry tool to loosen the faceplate from the phone.
  • Slide the pry tool along the entire crease of the faceplate to completely detach it.
Passo 6  ¶
Separate the faceplate from the phone. Separate the faceplate from the phone. Separate the faceplate from the phone.
Passo 6  ¶
  • Separate the faceplate from the phone.
