Pular para o conteúdo principal
Ajuda
Olympus Stylus 410 LCD Screen Replacement
Pré-requisitos ausentes
Este guia está faltando informações sobre como começar. Faça um guia de início!
Texto confuso
Texto confuso
Alguns dos textos deste guia é confuso, duplicado ou fora-tópico. Melhore-o!
  • Autor: Rory Aronson
  • Tempo estimado: 30 - 45 minutos
  • Dificuldade: Moderado
If the screen on your Olympus Stylus 410 is cracked and/or no longer works, use this repair guide to install a new one.
Seções
Ferramentas
Passo 1 LCD Screen  ¶
Remove the metal frame from the LCD screen using a spudger. Remove the metal frame from the LCD screen using a spudger. Remove the metal frame from the LCD screen using a spudger.
  • Remove the metal frame from the LCD screen using a spudger.
Passo 2  ¶
Pry off the LCD screen from the top using a spudger.  The screen will not be completely free from the device because of a ribbon. Do not pull the screen completely off because it will still be held on by two ribbon cables. Do not pull the screen completely off because it will still be held on by two ribbon cables.
Passo 2  ¶
  • Pry off the LCD screen from the top using a spudger. The screen will not be completely free from the device because of a ribbon.
  • Do not pull the screen completely off because it will still be held on by two ribbon cables.
Passo 3  ¶
This is what the camera will look like now that the LCD screen is removed.
Passo 3  ¶
  • This is what the camera will look like now that the LCD screen is removed.
