Pular para o conteúdo principal
Ajuda
Vaio FS series VGRFS640 CD DVD drive Replacement
Precisa de melhores imagens
Melhores fotos vão melhorar este guia. Ajude tirando, editando ou enviando novas delas!
Acidente de Marcação
Este guia precisa de melhores marcações. Ajude corrigindo ou fazendo algumas marcações.
The CD/DVD drive is what allows a computer to read and write CDs or DVDs. If this isn't working properly it can be a hinderance to the laptop's usability.
  • Autor: Geoffrey
  • Tempo estimado: 30 minutos
  • Dificuldade: Moderado
This guide will instruct you, step by step, in how to remove and replace the disk drive in your Vaio VGRFS640.
Seções
Ferramentas
Partes relevantes
Passo 1 CD DVD drive  ¶
Unscrew the screws holding in the CD/ DVD drive. Unscrew the screws holding in the CD/ DVD drive.
  • Unscrew the screws holding in the CD/ DVD drive.
Passo 2  ¶
Remove the CD/ DVD drive by gently lifting it up and out of the laptop. Remove the CD/ DVD drive by gently lifting it up and out of the laptop.
Passo 2  ¶
  • Remove the CD/ DVD drive by gently lifting it up and out of the laptop.
Passo 3  ¶
Get the new CD/ DVD drive. Make sure that the new CD/ DVD drive is compatable with the Vaio VGRFS640
Passo 3  ¶
  • Get the new CD/ DVD drive.
  • Make sure that the new CD/ DVD drive is compatable with the Vaio VGRFS640
  • Sony no-longer has a list of compatable drivers, however the original driver can be found here under optical drive.
