Pular para o conteúdo principal
Ajuda
Motorola V60c Side Buttons Replacement
Acidente de Marcação
Este guia precisa de melhores marcações. Ajude corrigindo ou fazendo algumas marcações.
Pré-requisitos ausentes
Este guia está faltando informações sobre como começar. Faça um guia de início!
  • Autor: Ryan Kuroiwa
  • Tempo estimado: 10 - 15 minutos
  • Dificuldade: Fácil
How to replace the side buttons.
Passo 1 Side Buttons  ¶
Remove 4 screws from corners using T-6 screwdriver.
  • Remove 4 screws from corners using T-6 screwdriver.
  • NOTE: Bottom two screws are gold.
  • NOTE: Make sure screws return to correct place when reassembling.
Passo 2  ¶
Use a plastic opening tool to pry up back cover from two side clips. NOTE: sticker might be attached to rest of phone.
Passo 2  ¶
  • Use a plastic opening tool to pry up back cover from two side clips.
  • NOTE: sticker might be attached to rest of phone.
Passo 3  ¶
Remove the back cover.
Passo 3  ¶
  • Remove the back cover.
Passo 4  ¶
Use a plastic opening tool to gently remove the orange ribbon cable. Lift up the main logic board.
Passo 4  ¶
  • Use a plastic opening tool to gently remove the orange ribbon cable.
  • Lift up the main logic board.
  • NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
Passo 5  ¶
Carefully flip over main logic board. Remove rubber side buttons.
Passo 5  ¶
  • Carefully flip over main logic board.
  • Remove rubber side buttons.
