Pular para o conteúdo principal
Ajuda
Sega Game Gear Screen Replacement
Guia em destaque
Guia em destaque
Este guia foi considerado super bacana pela equipe da iFixit.
Use this guide to instal a replacement screen.
  • Autor: Lauren Thurston
  • Tempo estimado: 30 - 45 minutos
  • Dificuldade: Moderado
A guide to installing a replacement screen on a Sega Game Gear.
Seções
Ferramentas
Passo 1 Screen  ¶
Unscrew all the marked screws.
Passo 1 Screen  ¶
  • Unscrew all the marked screws.
Passo 2  ¶
Slide the logic board out from under the circular black fastener at the top-left corner of the case.
Passo 2  ¶
  • Slide the logic board out from under the circular black fastener at the top-left corner of the case.
Passo 3  ¶
Place the board onto a flat surface.
Passo 3  ¶
  • Place the board onto a flat surface.
  • Small plastic buttons may fall off during this process, save them in a container or a place where they could be found later on.
Passo 4  ¶
Unscrew the marked screws.
Passo 4  ¶
  • Unscrew the marked screws.
  • Flip the board, having its back facing up.
  • Hold onto the screen in the back, as it will flip open if not held onto.
Passo 5  ¶
Make sure the screen is towards the bottom, as indicated in the second picture. Make sure the screen is towards the bottom, as indicated in the second picture.
Passo 5  ¶
  • Make sure the screen is towards the bottom, as indicated in the second picture.
Passo 6  ¶
Gently open the screen up. The screen will not come out all the way since it is glued onto the top side.
Passo 6  ¶
  • Gently open the screen up.
  • The screen will not come out all the way since it is glued onto the top side.
