Pular para o conteúdo principal
Ajuda
Canon PowerShot SD450 LCD Screen Replacement
Acidente de Marcação
Este guia precisa de melhores marcações. Ajude corrigindo ou fazendo algumas marcações.
Pré-requisitos ausentes
Este guia está faltando informações sobre como começar. Faça um guia de início!
Removing the LCD screen for replacement.
Seções
Ferramentas
Passo 1 LCD Screen  ¶
Pull the retaining clip up with the spudger or your finger and remove the ribbon from the socket. Pull the retaining clip up with the spudger or your finger and remove the ribbon from the socket.
  • Pull the retaining clip up with the spudger or your finger and remove the ribbon from the socket.
Passo 2  ¶
Remove the tripod mount screw.
Passo 2  ¶
  • Remove the tripod mount screw.
  • Turn the camera around so that the screen is facing you, and the camera is upright.
Passo 3  ¶
Remove the screw at the top right of the screen.
Passo 3  ¶
  • Remove the screw at the top right of the screen.
Passo 4  ¶
Lift up the screen to reveal the tripod mount screw.
Passo 4  ¶
  • Lift up the screen to reveal the tripod mount screw.
Passo 5  ¶
Remove the last screw holding the tripod mount to the case. The LCD ribbon threads under the mount, so upon reinstallation, the ribbon will need to be threaded through before the mount is reattached. Take note of the tripod mount orientation.
Passo 5  ¶
  • Remove the last screw holding the tripod mount to the case. The LCD ribbon threads under the mount, so upon reinstallation, the ribbon will need to be threaded through before the mount is reattached. Take note of the tripod mount orientation.
Passo 6  ¶
Pull the back light ribbon from it's socket to remove the LCD completely. There is a little hole you can stick the spudger into to help release the ribbon.
Passo 6  ¶
  • Pull the back light ribbon from it's socket to remove the LCD completely. There is a little hole you can stick the spudger into to help release the ribbon.
