Pular para o conteúdo principal
Ajuda
Samsung SCH-A670 Logic Board Replacement
Fotos de ação
Fotos de ação
Seja um herói em ação! Este guia precisa de imagens que melhor demonstrem como executar ações específicas.
  • Autor: Nathan Brink
  • Tempo estimado: 5 - 10 minutos
  • Dificuldade: Fácil
It may become necessary to replace the logic board on this cell phone in order to correct a problem. Following this guide will make removal quite easy.
Passo 1 Logic Board  ¶
After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
Passo 2  ¶
Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
Passo 2  ¶
  • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
Passo 3  ¶
With a #0 Phillips screwdriver remove the screw which you just uncovered.
Passo 3  ¶
  • With a #0 Phillips screwdriver remove the screw which you just uncovered.
Passo 4  ¶
Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open. Then disconnect the small power connector near the top of the phone.
Passo 4  ¶
  • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
  • Then disconnect the small power connector near the top of the phone.
Passo 5  ¶
Gently pry up the ribbon-type connector with the spudger.
Passo 5  ¶
  • Gently pry up the ribbon-type connector with the spudger.
Passo 6  ¶
Carefully pry the logic board from the case with the spudger.
Passo 6  ¶
  • Carefully pry the logic board from the case with the spudger.
