Pular para o conteúdo principal
Ajuda
DualShock 4 Touch Pad Replacement
Remove the touchpad on the Dualshock 4 controller.
  • Autor: Mark
  • Tempo estimado: 20 minutos
  • Dificuldade: Moderado
Use this guide to remove a defective touchpad on a Dualshock 4 controller.
Passo 1 Touch Pad  ¶
After the motherboard is set aside, lay the front panel on the ground.
Passo 1 Touch Pad  ¶
  • After the motherboard is set aside, lay the front panel on the ground.
  • You can now see the touch pad which is outlined on the top and bottom by an orange line.
Passo 2  ¶
Now pick the front panel up, and use one hand to press the touch pad up from the front of the panel. There are no other restrictions attached to the touch pad. It should slide right out and back in without any effort. There are no other restrictions attached to the touch pad. It should slide right out and back in without any effort.
Passo 2  ¶
  • Now pick the front panel up, and use one hand to press the touch pad up from the front of the panel.
  • There are no other restrictions attached to the touch pad. It should slide right out and back in without any effort.
