Pular para o conteúdo principal
Ajuda
iRobot Roomba 551 Bumper Sensor Replacement
Guia do aluno destaque
Este guia tem sido o trabalho duro de nossos alunos incríveis e é considerado extremamente bacana pelo equipe da iFixit.
This guide will provide steps needed to replace the bumper sensor on the iRobot Roomba 551.
  • Autor: Cody Rhoads
  • Tempo estimado: 10 - 30 minutos
  • Dificuldade: Moderado
Is your Roomba banging its head against the wall? Follow this guide to replace the bumper sensor.
Seções
Passo 1 Bumper Sensor  ¶
Flip the Roomba so that the bottom is facing you.
  • Flip the Roomba so that the bottom is facing you.
Passo 2  ¶
Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver. Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver.
Passo 2  ¶
  • Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver.
Passo 3  ¶
Pull gently on the bottom of the sensor to remove.
Passo 3  ¶
  • Pull gently on the bottom of the sensor to remove.
Passo 4  ¶
Flip the bumper over and lift the sensor from its compartment. You are now free to replace the bumper sensor. You are now free to replace the bumper sensor.
Passo 4  ¶
  • Flip the bumper over and lift the sensor from its compartment.
  • You are now free to replace the bumper sensor.
