Pular para o conteúdo principal
Ajuda
PowerBook G4 Aluminum 15" 1-1.5 GHz PRAM Battery Replacement
  • Autor: iRobot
  • Dificuldade: Difícil
The time and date, as well as other settings, are kept by the PRAM battery when your machine is off.
Passo 1 PRAM Battery  ¶
Use a spudger to pry up the PRAM battery from the optical drive.
  • Use a spudger to pry up the PRAM battery from the optical drive.
Passo 2  ¶
Disconnect the PRAM battery cable from the logic board and pull the PRAM battery out.
Passo 2  ¶
  • Disconnect the PRAM battery cable from the logic board and pull the PRAM battery out.
