Pular para o conteúdo principal
Ajuda
iPhone 5s Front Facing Camera and Sensor Cable Replacement
Replace a faulty front-facing camera or other malfunctioning part of the front-facing camera and sensor cable in an iPhone 5s.
  • Autor: Sam Goldheart
  • Tempo estimado: 30 minutos
  • Dificuldade: Moderado
Use this guide to replace the sensor cable containing the front-facing camera, microphone, ambient sensors, and the earpiece speaker contact pad, in your iPhone 5s.
You can also use this guide to replace the following parts:
Passo 1 Front Facing Camera and Sensor Cable  ¶
Remove any plastic coverings from the microphone on the sensor cable assembly.
  • Remove any plastic coverings from the microphone on the sensor cable assembly.
Passo 2  ¶
Remove any clear backing strips from the light sensor, cable and front-facing camera. Remove any clear backing strips from the light sensor, cable and front-facing camera. Remove any clear backing strips from the light sensor, cable and front-facing camera.
Passo 2  ¶
  • Remove any clear backing strips from the light sensor, cable and front-facing camera.
Passo 3  ¶
In order to ensure a good fit and proper placement of components, make sure your new cable assembly matches the one that came out of your iPhone. You may need to use a set of tweezers to fold the microphone portion of the cable so that the gold portion is inside the cable, and the silver unit is on top.
Passo 3  ¶
  • In order to ensure a good fit and proper placement of components, make sure your new cable assembly matches the one that came out of your iPhone.
  • You may need to use a set of tweezers to fold the microphone portion of the cable so that the gold portion is inside the cable, and the silver unit is on top.
