Pular para o conteúdo principal
Ajuda
Disassembling Weather Box Oregon BAR800
Teardown
Teardown
As desmontagens servem para mostrar o que tem dentro de um/uma device e não devem ser usadas como instruções de procedimento.
Guia contribuído por membro
Um membro impressionante de nossa comunidade fez este guia. Não é gerenciado pela equipe iFixit.
Passo 1 Disassembling Weather Box Oregon BAR800  ¶
Weather Box, front side
  • Weather Box, front side
Passo 2  ¶
Rear side Rear side Rear side
Passo 2  ¶
  • Rear side
Passo 3  ¶
External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
Passo 3  ¶
  • External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
  • Be carefull to not damage external plastic with knife
Passo 4  ¶
After plastic screen removed, it can see the screws. With a small screw driver, take them off. There are eight screws. With a small screw driver, take them off. There are eight screws.
Passo 4  ¶
  • After plastic screen removed, it can see the screws.
  • With a small screw driver, take them off. There are eight screws.
Passo 5  ¶
After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
Passo 5  ¶
  • After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
Passo 6  ¶
Internal view Internal view Internal view
Passo 6  ¶
  • Internal view
