Pular para o conteúdo principal
Ajuda
Canon Powershot A70 Viewfidner Replacement
Precisa de melhores imagens
Melhores fotos vão melhorar este guia. Ajude tirando, editando ou enviando novas delas!
Polícia gramatical
Polícia gramatical
Abrace seu professor de Inglês interior e ajude a melhorar a gramática deste guia!
  • Autor: Logan
  • Tempo estimado: 20 minutos
  • Dificuldade: Moderado
This guide will walk you through removing a faulty or damaged viewfinder.
Passo 1 Viewfinder  ¶
After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
  • After removing the front and rear panels, locate the viewfinder directly above the lens on top of the camera.
  • Three screws hold the viewfinder in place. Two on the top and one on the lens side of the camera.
  • First, remove the screw in the bent corner of the viewfinder.
Passo 2  ¶
Next, remove the 2nd screw directly across from the bent corner.  It may be hidden in the space under the orange circuitry.
Passo 2  ¶
  • Next, remove the 2nd screw directly across from the bent corner. It may be hidden in the space under the orange circuitry.
Passo 3  ¶
Lastly, remove the final screw directly under the left side of the viewfinder (on the lens side).
Passo 3  ¶
  • Lastly, remove the final screw directly under the left side of the viewfinder (on the lens side).
Passo 4  ¶
After removing the three screws, the only thing still holding the viewfinder in place is a small plastic peg.
Passo 4  ¶
  • After removing the three screws, the only thing still holding the viewfinder in place is a small plastic peg.
  • Remove the viewfinder with a firm pull directly upwards.
