Pular para o conteúdo principal
Ajuda
Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement
Precisa de melhores imagens
Melhores fotos vão melhorar este guia. Ajude tirando, editando ou enviando novas delas!
Precisa de mais images
Mais algumas imagens faria os procedimentos deste guia ficarem mais claros.
Ajustador de passo
Ajustador de passo
Este guia tem passos desnecessários. Tente ser mais conciso!
Can't hear anything? There is likely an issue with your device's headphone jack. Follow this guide to fix the issue.
  • Autor: James Thorne
  • Tempo estimado: 15 minutos
  • Dificuldade: Moderado
Follow this guide to replace a faulty headphone jack in your Sandisk Sansa m230 Series MP3 Player.
Passo 1 Headphone Jack  ¶
Locate the headphone jack on the motherboard.
  • Locate the headphone jack on the motherboard.
Passo 2  ¶
Ensure the hot end of the soldering iron is elevated on a metal stand when not in use to prevent burns.
Passo 2  ¶
  • Ensure the hot end of the soldering iron is elevated on a metal stand when not in use to prevent burns.
  • The solder and soldering iron are very hot! Do not touch unless you are wearing appropriate protective gloves.
Passo 3  ¶
Use soldering iron to melt the existing solder at the three headphone jack connections. Use soldering iron to melt the existing solder at the three headphone jack connections. Use soldering iron to melt the existing solder at the three headphone jack connections.
Passo 3  ¶
  • Use soldering iron to melt the existing solder at the three headphone jack connections.
Passo 4  ¶
Remove the faulty headphone jack from the motherboard.
Passo 4  ¶
  • Remove the faulty headphone jack from the motherboard.
Passo 5  ¶
Align the new headphone jack appropriately on the motherboard for soldering.
Passo 5  ¶
  • Align the new headphone jack appropriately on the motherboard for soldering.
Passo 6  ¶
Use the soldering iron and solder to create three stable connections between the motherboard and the headphone jack. Allow the new solder to cool and harden before reassembling the MP3 player. Allow the new solder to cool and harden before reassembling the MP3 player.
Passo 6  ¶
  • Use the soldering iron and solder to create three stable connections between the motherboard and the headphone jack.
  • Allow the new solder to cool and harden before reassembling the MP3 player.
