Pular para o conteúdo principal
Ajuda
Sandisk Sansa m230 Series mp3 player Teardown
Teardown
Teardown
As desmontagens servem para mostrar o que tem dentro de um/uma device e não devem ser usadas como instruções de procedimento.
Precisa de melhores imagens
Melhores fotos vão melhorar este guia. Ajude tirando, editando ou enviando novas delas!
Precisa de mais images
Mais algumas imagens faria os procedimentos deste guia ficarem mais claros.
Follow the steps in this guide in order to gain access to components found inside the device which most often require repair of replacement.
Passo 1 Sandisk Sansa m230 Series mp3 player Teardown  ¶
Remove the battery compartment cover.
  • Remove the battery compartment cover.
  • Remove the battery.
Passo 2  ¶
Locate and remove the screw next to the battery compartment lid.
Passo 2  ¶
  • Locate and remove the screw next to the battery compartment lid.
Passo 3  ¶
Locate the interlocking pegs along the seam of the device's casings.
Passo 3  ¶
  • Locate the interlocking pegs along the seam of the device's casings.
  • Gently pry the pegs apart one at a time, working your way around the case.
  • Be careful when prying apart the pegs: they are made of plastic and may break.
Passo 4  ¶
The battery contact springs may prevent the case from separating.
Passo 4  ¶
  • The battery contact springs may prevent the case from separating.
  • Push the battery contact springs down through the hole in the case.
Passo 5  ¶
The casing protecting the USB and headphone jacks must be removed.
Passo 5  ¶
  • The casing protecting the USB and headphone jacks must be removed.
  • Locate and gently pry apart the two interlocking clips holding it in place.
  • The outer casings may now be removed and the MP3 player should separate.
Passo 6  ¶
You now have access to all components found on the inside of the device!
Passo 6  ¶
  • You now have access to all components found on the inside of the device!
