Pular para o conteúdo principal
Ajuda
Samsung SPH-A660 Logic Board Replacement
Precisa de melhores imagens
Melhores fotos vão melhorar este guia. Ajude tirando, editando ou enviando novas delas!
Polícia gramatical
Polícia gramatical
Abrace seu professor de Inglês interior e ajude a melhorar a gramática deste guia!
  • Autor: Kyle Cole
  • Tempo estimado: 2 minutos
  • Dificuldade: Muito fácil
Do you need to replace your logic board? To do so, follow these steps to remove your old one and just perform them in reverse with the new logic board to reassemble.
Passo 1 Logic Board  ¶
Once the battery pack is removed from the phone, remove the five indicated screws with a size #00 Philips screwdriver. Bend back the antenna to access the indicated left middle screw in order to unscrew it.
  • Once the battery pack is removed from the phone, remove the five indicated screws with a size #00 Philips screwdriver.
  • Bend back the antenna to access the indicated left middle screw in order to unscrew it.
  • Do not forget to unscrew the indicated screw on the top left corner of the phone as it will be difficult in further steps to take the phone apart if this screw is left in.
Passo 2  ¶
Place the phone on its side. Insert the small plastic opening tool into the slot that runs along the side of the phone. Slowly pry open the phone by working your way around the edges of the phone with the opening tool.
Passo 2  ¶
  • Place the phone on its side.
  • Insert the small plastic opening tool into the slot that runs along the side of the phone.
  • Slowly pry open the phone by working your way around the edges of the phone with the opening tool.
  • There are tabs that run the entire length of the phone which hold the phone together and you may need a significant amount of force to pry the phone apart.
  • During this step, the side volume key may fall out; this is okay.
Passo 3  ¶
Carefully lift up on the highlighted connector between the logic board and the screen by using either your fingers or a plastic opening tool as shown in the picture.
Passo 3  ¶
  • Carefully lift up on the highlighted connector between the logic board and the screen by using either your fingers or a plastic opening tool as shown in the picture.
Passo 4  ¶
Remove the entire green logic board from the phone by gently lifting up on the large green logic board with the plastic opening tool. Use caution not to break any components of the logic board Set the green logic board aside. The keypad may fall out, this is okay. Set it aside.
Passo 4  ¶
  • Remove the entire green logic board from the phone by gently lifting up on the large green logic board with the plastic opening tool. Use caution not to break any components of the logic board
  • Set the green logic board aside.
  • The keypad may fall out, this is okay. Set it aside.
