Pular para o conteúdo principal
Ajuda
Velocity NoteMagix M10 A82 Keyboard Replacement
Guia em destaque
Guia em destaque
Este guia foi considerado super bacana pela equipe da iFixit.
You will be replacing the keyboard.
  • Autor: Sam Middleton
  • Tempo estimado: 5 - 15 minutos
  • Dificuldade: Fácil
In this guide you will remove a total of three pieces to replace the keyboard. It will be a combination of prying and pulling to complete the task. During this process, it would be a good idea to have some electrical cleaner handy to clean the connections and the plastic pieces of all unwanted residue. This is an easy replacement and can be done within an hour. The only tools needed will be a spudger.
Seções
Ferramentas
Partes relevantes
Passo 1 Keyboard  ¶
Place the laptop fully opened with the keyboard facing upwards.
Passo 1 Keyboard  ¶
  • Place the laptop fully opened with the keyboard facing upwards.
  • Remove the hinge cover by wedging the spudger underneath at the bottom edge and gently prying upwards while sliding the spudger along the cover.
Passo 2  ¶
Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
Passo 2  ¶
  • Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
  • Pull the keyboard away from the mousepad.
  • Be careful to not damage the ribbon underneath the keyboard that connects the keyboard to the computer during removal.
Passo 3  ¶
Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
Passo 3  ¶
  • Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
