Pular para o conteúdo principal
Ajuda
Acer Chromebook C710 Hard Drive Replacement
This guide will show you how to replace the hard drive.
  • Autor: Bradley Pavy
  • Tempo estimado: 3 - 5 minutos
  • Dificuldade: Moderado
If you experiencing problems listed in the troubleshooting guide, you can replace the hard drive. The hard drive stores the operating system (Chrome OS), along with saved files and pictures. Installing a new hard drive will require reinstalling Chrome OS and backing up your local files.
Seções
Ferramentas
Passo 1 Hard Drive  ¶
The hard drive assembly is attached to the laptop by a ribbon cable. Only lift the side of the drive facing you about an inch above the laptop. If you tear the ribbon cable the laptop will need to be serviced by a professional. Use one finger to lift up the hard drive assembly from the bottom left corner.
  • The hard drive assembly is attached to the laptop by a ribbon cable. Only lift the side of the drive facing you about an inch above the laptop. If you tear the ribbon cable the laptop will need to be serviced by a professional.
  • Use one finger to lift up the hard drive assembly from the bottom left corner.
Passo 2  ¶
Hold the hard drive assembly keeping the end closest to you near the laptop. It's ok to tilt the far end of the drive up towards you. Unscrew the two silver #0 3mm Phillips screws on the left and right sides of the hard drive.
Passo 2  ¶
  • Hold the hard drive assembly keeping the end closest to you near the laptop. It's ok to tilt the far end of the drive up towards you.
  • Unscrew the two silver #0 3mm Phillips screws on the left and right sides of the hard drive.
Passo 3  ¶
Hold the base of the hard drive in your right hand. Use your left hand to pull the hard drive away from its housing. Don't let the housing tug on the ribbon cable. Use your left hand to pull the hard drive away from its housing. Don't let the housing tug on the ribbon cable.
Passo 3  ¶
  • Hold the base of the hard drive in your right hand.
  • Use your left hand to pull the hard drive away from its housing. Don't let the housing tug on the ribbon cable.
