Pular para o conteúdo principal
Ajuda
Samsung SCH-A950 Logic Board Replacement
  • Autor: Alan Cook
  • Tempo estimado: 5 - 10 minutos
  • Dificuldade: Moderado
This guide will teach you how to remove your Samsung SCH-A950's logic board.
Seções
Passo 1 Logic Board  ¶
Using a plastic opening tool, disconnect the display cable from the motherboard.
  • Using a plastic opening tool, disconnect the display cable from the motherboard.
Passo 2  ¶
Use a plastic opening tool to pry the  motherboard away from the phone housing at the tabs on both sides of the phone at the pictured location. Some force may be required.
Passo 2  ¶
  • Use a plastic opening tool to pry the motherboard away from the phone housing at the tabs on both sides of the phone at the pictured location. Some force may be required.
Passo 3  ¶
The logic board will pop out.
Passo 3  ¶
  • The logic board will pop out.
  • The logic board can be replaced if needed.
