Pular para o conteúdo principal
Ajuda
MacBook Unibody Model A1342 Hard Drive Cable Replacement
  • Autor: Walter Galan
  • Tempo estimado: 10 - 40 minutos
  • Dificuldade: Moderado
This guide will show you how to replace the hard drive cable.
Passo 1 Hard Drive Cable  ¶
Remove the 3.1 mm Phillips screw securing the hard drive cable to the upper case.
  • Remove the 3.1 mm Phillips screw securing the hard drive cable to the upper case.
Passo 2  ¶
Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
Passo 2  ¶
  • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
  • Remove the hard drive cable from the upper case.
