Pular para o conteúdo principal
Ajuda
Panasonic Lumix DMC-ZS3 Back Cover Replacement
Texto confuso
Texto confuso
Alguns dos textos deste guia é confuso, duplicado ou fora-tópico. Melhore-o!
Precisa de melhores imagens
Melhores fotos vão melhorar este guia. Ajude tirando, editando ou enviando novas delas!
Replace the back cover of your Panasonic Lumix DMC-ZS3
Use this guide to replace the back cover which houses the back panel buttons and LCD screen.
Passo 1 Back Cover  ¶
Remove the following eleven screws securing the covers to the ZS3 Eleven 3 mm Phillips screws Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  • Remove the following eleven screws securing the covers to the ZS3
  • Eleven 3 mm Phillips screws
  • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
Passo 2  ¶
Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown. Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
Passo 2  ¶
  • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
  • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
Passo 3  ¶
Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit. Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
Passo 3  ¶
  • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
  • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
Passo 4  ¶
Remove the two LCD board ribbon cables out of their sockets.
Passo 4  ¶
  • Remove the two LCD board ribbon cables out of their sockets.
