Pular para o conteúdo principal
Ajuda
Canon PowerShot SD 600 Motherboard Replacement
The motherboard is the main circuit board of the camera. It is located at the front of the camera and can be removed at roughly the same time as lens assembly and flash assembly.
  • Autor: Greg H
  • Dificuldade: Moderado
Seções (continuação)
Ferramentas
Passo 1 Motherboard  ¶
Unsnap the connector that runs from the rear accessory board to the front of the camera. The motherboard can be removed at roughly the same time as the lens assembly and the flash assembly. The cables that run to each of these components should also be disconnected if they have not been.
  • Unsnap the connector that runs from the rear accessory board to the front of the camera.
  • The motherboard can be removed at roughly the same time as the lens assembly and the flash assembly. The cables that run to each of these components should also be disconnected if they have not been.
Passo 2  ¶
The motherboard can now be lifted out and separated from the rest of the camera. The motherboard can now be lifted out and separated from the rest of the camera.
Passo 2  ¶
  • The motherboard can now be lifted out and separated from the rest of the camera.
