Pular para o conteúdo principal
Ajuda
Canon PowerShot SD 600 LCD Screen Replacement
Before attempting this guide, you should have already removed the front and rear exterior covers of the camera. The guide for how to do this can be found on the main page.
  • Autor: Greg H
  • Dificuldade: Moderado
Passo 1 LCD Screen  ¶
Disconnect the cable that connects the screen to the front motherboard. Using a spudger, unsnap the jawbone connector that holds the cable in Gently pull the cable out using the spudger.
  • Disconnect the cable that connects the screen to the front motherboard.
  • Using a spudger, unsnap the jawbone connector that holds the cable in
  • Gently pull the cable out using the spudger.
Passo 2  ¶
At the back of the camera, there are four 2.5mm screws that will need to be removed in order for the screen to pull off. One at the top of the camera that is connected to a bracket that secures the screen. Two on the back of the camera,near the speaker.
Passo 2  ¶
  • At the back of the camera, there are four 2.5mm screws that will need to be removed in order for the screen to pull off.
  • One at the top of the camera that is connected to a bracket that secures the screen.
  • Two on the back of the camera,near the speaker.
  • One hidden behind the bracket.
Passo 3  ¶
Gently lift the screen and pull it apart from the camera, taking care to unslot the screen brackets from the tabs on the bottom and left side of the camera. Do not pull too hard on the screen as there is still another delicate cable running from the screen to the rear board of the camera. Gently pull the wide ribbon (shown in an earlier step) cable from the front of the camera to the back using tweezers.
Passo 3  ¶
  • Gently lift the screen and pull it apart from the camera, taking care to unslot the screen brackets from the tabs on the bottom and left side of the camera.
  • Do not pull too hard on the screen as there is still another delicate cable running from the screen to the rear board of the camera.
  • Gently pull the wide ribbon (shown in an earlier step) cable from the front of the camera to the back using tweezers.
Passo 4  ¶
The screen is now connected only by a small cable that runs to the rear board of the camera. Using tweezers, slowly pull the cable out of the connector. For best results, grip the cable as close to the connector as possible. The screen should now be separate from the camera body. Be careful not to harm the connectors on the lens so it will reconnect successfully.
Passo 4  ¶
  • The screen is now connected only by a small cable that runs to the rear board of the camera. Using tweezers, slowly pull the cable out of the connector.
  • For best results, grip the cable as close to the connector as possible.
  • The screen should now be separate from the camera body. Be careful not to harm the connectors on the lens so it will reconnect successfully.
