Pular para o conteúdo principal
Ajuda
Sanyo Katana Back Casing Replacement
This guide describes the installation process for the back outer casing of the device.
  • Autor: Preston
  • Tempo estimado: 5 - 10 minutos
  • Dificuldade: Moderado
In this guide the entire back case will be removed from the device, including the battery and battery cover. A screwdriver will be used in during the guide.
Seções
Ferramentas
Passo 1 Back Casing  ¶
Using a spudger, remove the four rubber coverings on the lower back plate.
  • Using a spudger, remove the four rubber coverings on the lower back plate.
Passo 2  ¶
Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate. Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate. Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
Passo 2  ¶
  • Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
Passo 3  ¶
Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate. Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate. Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
Passo 3  ¶
  • Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
