Pular para o conteúdo principal
Ajuda
Dell Inspiron n5050 RAM Replacement
Em progresso
Em progresso
Este guia está em progresso. Atualize para acompanhar as últimas mudanças!
Guia contribuído por membro
Um membro impressionante de nossa comunidade fez este guia. Não é gerenciado pela equipe iFixit.
How to access your RAM for re-seating or replacement.
  • Autor: Tyler
  • Dificuldade: Moderado
Sometimes RAM might need to be re-seated to get a computer to work again. Or, you might just want to upgrade the amount of RAM in your computer. Either way, this guide will help you do it.
Seções
Ferramentas
Partes relevantes
Passo 1 RAM  ¶
Locate RAM Push outwards on both retaining clips, the RAM will pop up slightly when it is free from the clips. Push outwards on both retaining clips, the RAM will pop up slightly when it is free from the clips.
Passo 1 RAM  ¶
  • Locate RAM
  • Push outwards on both retaining clips, the RAM will pop up slightly when it is free from the clips.
Passo 2  ¶
The RAM will pop up, and then you can slide it out at the same angle it is at.
Passo 2  ¶
  • The RAM will pop up, and then you can slide it out at the same angle it is at.
