Pular para o conteúdo principal
Ajuda
MacBook Pro 13" Retina Display Late 2012 Right Fan Replacement
Replace the Right Fan in your MacBook Pro 13" Retina Display Late 2012.
Use this guide to replace the right fan.
Passo 1 Right Fan  ¶
Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket. Be sure you are prying up on the hinged retaining flap, not the socket itself. Pull the right fan ribbon cable straight out of its socket on the logic board.
Passo 1 Right Fan  ¶
  • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Pull the right fan ribbon cable straight out of its socket on the logic board.
Passo 2  ¶
Remove the three 3.1 mm T5 Torx screws securing the right fan to the logic board assembly.
Passo 2  ¶
  • Remove the three 3.1 mm T5 Torx screws securing the right fan to the logic board assembly.
Passo 3  ¶
Lift and remove the right fan out of the upper case.
Passo 3  ¶
  • Lift and remove the right fan out of the upper case.
