Pular para o conteúdo principal
Ajuda
Kindle Paperwhite 1st Generation Motherboard Replacement
Guia em destaque
Guia em destaque
Este guia foi considerado super bacana pela equipe da iFixit.
How to dissemble a Kindle Paperwhite in order to replace the motherboard.
Replace your Kindle's old motherboard with a new one.
Seções
Passo 1 Motherboard  ¶
With the case and battery removed from the midframe, begin removing all cables attached to the motherboard. Place the device so the midframe's backside faces up. Start with the cable on the bottom left corner. Use a spudger to lift up the white locking cable tensioner and slide the flex cable out.
  • With the case and battery removed from the midframe, begin removing all cables attached to the motherboard.
  • Place the device so the midframe's backside faces up. Start with the cable on the bottom left corner.
  • Use a spudger to lift up the white locking cable tensioner and slide the flex cable out.
  • Proceed counterclockwise to the next cable and repeat. Small flex cable on the bottom won't need cable tensioner lifted, just carefully pull out.
Passo 2  ¶
Remove the white flex cable by gently lifting the yellow plastic connector. Remove the white flex cable by gently lifting the yellow plastic connector.
Passo 2  ¶
  • Remove the white flex cable by gently lifting the yellow plastic connector.
Passo 3  ¶
Remove the yellow anti-static tape from the display ribbon cable connector. Use a spudger to lift up and disconnect the cable tensioner. Use a spudger to lift up and disconnect the cable tensioner.
Passo 3  ¶
  • Remove the yellow anti-static tape from the display ribbon cable connector.
  • Use a spudger to lift up and disconnect the cable tensioner.
Passo 4  ¶
Use a Philips screwdriver to remove the seven 3.0 mm Phillips screws securing the motherboard: Three silver screws with silver washers
Passo 4  ¶
  • Use a Philips screwdriver to remove the seven 3.0 mm Phillips screws securing the motherboard:
  • Three silver screws with silver washers
  • Two silver screws with no washers
  • One black screw with a golden washer
  • One black screw with a square washer
Passo 5  ¶
Remove the motherboard.
Passo 5  ¶
  • Remove the motherboard.
