Pular para o conteúdo principal
Ajuda
Toshiba Satellite L655D-S5095 Keyboard Replacement
Acidente de Marcação
Este guia precisa de melhores marcações. Ajude corrigindo ou fazendo algumas marcações.
Precisa de mais images
Mais algumas imagens faria os procedimentos deste guia ficarem mais claros.
Replace your Toshiba Satellite's undersized space bar and the rest of your keyboard.
  • Autor: Jerry Wakai
  • Tempo estimado: 5 - 7 minutos
  • Dificuldade: Fácil
Replacing the keyboard is an intermediate level repair. Following the instructions carefully will help you successfully replace your keyboard.
Passo 1 Keyboard  ¶
Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
Passo 1 Keyboard  ¶
  • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
Passo 2  ¶
Use a plastic opening tool to pry off the plastic panel above the keyboard.
Passo 2  ¶
  • Use a plastic opening tool to pry off the plastic panel above the keyboard.
Passo 3  ¶
Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver. Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
Passo 3  ¶
  • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
Passo 4  ¶
Slowly lift the keyboard out, up and towards the screen.
Passo 4  ¶
  • Slowly lift the keyboard out, up and towards the screen.
  • Do not try to remove the keyboard completely because it is still attached to the motherboard.
Passo 5  ¶
Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
Passo 5  ¶
  • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
