Pular para o conteúdo principal
Ajuda
Samsung Galaxy S Vibrant LCD Screen Replacement
Faltou uma etapa
Faltou uma etapa
Ops! Este guia está faltando alguns passos importantes.
A brief guide on how to replace your Samsung Galaxy S Vibrant’s screen.
  • Autor: Taylor Catlin
  • Tempo estimado: 20 - 30 minutos
  • Dificuldade: Moderado
Drop your phone one too many times? Cracked screen? Replace it quickly and at a low cost by following this guide.
Passo 1 LCD Screen  ¶
Use a heat gun or hairdryer to loosen the adhesive that secures the touch panel to the screen assembly.
  • Use a heat gun or hairdryer to loosen the adhesive that secures the touch panel to the screen assembly.
  • Wear heat resistant gloves when removing the screen.
Passo 2  ¶
Use a plastic opening tool or guitar pick to carefully remove the touch panel from the screen assembly. Start from the top edge and carefully wedge your tool between the screen and frame.
Passo 2  ¶
  • Use a plastic opening tool or guitar pick to carefully remove the touch panel from the screen assembly.
  • Start from the top edge and carefully wedge your tool between the screen and frame.
  • Carefully slide your tool along the framework.
  • If the screen is cracked, cover the face in masking tape to prevent broken glass from chipping off.
  • You may need to reheat the adhesive as you work around the edges.
