Pular para o conteúdo principal
Ajuda
Disassembling HP Deskjet F4480 Top Lid
Acidente de Marcação
Este guia precisa de melhores marcações. Ajude corrigindo ou fazendo algumas marcações.
Removing the top cover of the printer is a prerequisite for most installations
  • Autor: Tim
  • Tempo estimado: 5 - 10 minutos
  • Dificuldade: Moderado
In order to gain access to most of the internal components the top (or lid) of the printer must be removed. This guide is intended as a prerequisite for other installations.
Passo 1 Removing Top Lid  ¶
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
Passo 2  ¶
Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top.
Passo 2  ¶
  • Remove the four 9mm T10 Torx screws on the top.
Passo 3  ¶
Carefully lift the top panel off of the printer. Do not tear or damage the two cables that connect the top lid to the motherboard.
Passo 3  ¶
  • Carefully lift the top panel off of the printer.
  • Do not tear or damage the two cables that connect the top lid to the motherboard.
Passo 4  ¶
Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
Passo 4  ¶
  • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
