Pular para o conteúdo principal
Ajuda
Lexmark Intuition S505 Duplex Unit Replacement
Polícia gramatical
Polícia gramatical
Abrace seu professor de Inglês interior e ajude a melhorar a gramática deste guia!
This guide will inform readers how to install the duplex unit of the printer.
  • Autor: Raymond
  • Tempo estimado: 1 minuto
  • Dificuldade: Muito fácil
The duplex unit allows the printer to print on the front and back of a page without having to manually flip over the paper.
Passo 1 Duplex Unit  ¶
Hold the button down with flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
  • Hold the button down with flat end away from the printer. When you hear a click, the duplex unit can be removed from the printer.
Passo 2  ¶
Remove the duplex unit from the back of the printer with the duplex unit is facing up. Remove the duplex unit from the back of the printer with the duplex unit is facing up.
Passo 2  ¶
  • Remove the duplex unit from the back of the printer with the duplex unit is facing up.
