Pular para o conteúdo principal
Ajuda
Microsoft Zune 30 GB Hard Drive Replacement
  • Autor: JAVS
  • Tempo estimado: 5 - 8 minutos
  • Dificuldade: Fácil
The 30 GB hard drive is attached to the logic board. The battery should be removed before any more disassembling of the Zune is to take place.
Seções
Passo 1 Hard Drive  ¶
Now the  back cover is off and the battery is removed, so the hard drive is clearly visible.
  • Now the back cover is off and the battery is removed, so the hard drive is clearly visible.
  • There are four 4.2 mm screws securing the hard drive to the logic board.
  • Remove all four screws using a Phillips #00 screwdriver.
  • Don't lose any of the screws! If necessary, use a magnetized screw driver.
Passo 2  ¶
Carefully tilt the hard drive up from the logic board.
Passo 2  ¶
  • Carefully tilt the hard drive up from the logic board.
  • Do not pull the hard drive all the way off. It is still connected to the logic board by a ribbon cable.
Passo 3  ¶
Flip the hard drive over the top to expose the ribbon cable.
Passo 3  ¶
  • Flip the hard drive over the top to expose the ribbon cable.
Passo 4  ¶
This may be difficult to move, so take your time and be careful. The ribbon cable is held in place by a black latch on the hard drive.
Passo 4  ¶
  • This may be difficult to move, so take your time and be careful.
  • The ribbon cable is held in place by a black latch on the hard drive.
  • Using a small flat head screwdriver, flip the black latch up 90 degrees.
  • Make sure you are only flipping the black latch. Do not try to lift any wires or the white connector piece.
Passo 5  ¶
Carefully detach the ribbon cable from the hard drive. Now you have completely detached the hard drive.
Passo 5  ¶
  • Carefully detach the ribbon cable from the hard drive.
  • Now you have completely detached the hard drive.
