Pular para o conteúdo principal
Ajuda
iPad Mini CDMA LCD Replacement
Replace the LCD in your iPad Mini CDMA.
Use this guide to replace the LCD.
Passo 1 LCD  ¶
Use a plastic opening tool to pry the LCD connector from its socket on the logic board. Do not pry against the large IC next to the connector, or you may break it. Gently pry from the side of the connector as shown.
Passo 1 LCD  ¶
  • Use a plastic opening tool to pry the LCD connector from its socket on the logic board.
  • Do not pry against the large IC next to the connector, or you may break it. Gently pry from the side of the connector as shown.
Passo 2  ¶
The LCD is still connected to the rest of the iPad by two wide strips of adhesive tape that run up from the inside of the rear case to the front bottom LCD frame. While holding the LCD with one hand, insert the flat end of a spudger between the LCD and tape on the iPad's right side. Slide the spudger outward, separating the tape, while gently lifting up on the LCD to pull it away from the tape.
Passo 2  ¶
  • The LCD is still connected to the rest of the iPad by two wide strips of adhesive tape that run up from the inside of the rear case to the front bottom LCD frame.
  • While holding the LCD with one hand, insert the flat end of a spudger between the LCD and tape on the iPad's right side.
  • Slide the spudger outward, separating the tape, while gently lifting up on the LCD to pull it away from the tape.
  • It may help to twist the spudger, to spread the gap the rest of the way and separate the LCD from the tape.
Passo 3  ¶
While still holding the LCD up with one hand, move on to the iPad's left side and repeat the previous step's procedure to separate the second piece of tape. Insert the flat end of a spudger between the LCD frame and tape, and slide outward while gently lifting up on the LCD. Insert the flat end of a spudger between the LCD frame and tape, and slide outward while gently lifting up on the LCD.
Passo 3  ¶
  • While still holding the LCD up with one hand, move on to the iPad's left side and repeat the previous step's procedure to separate the second piece of tape.
  • Insert the flat end of a spudger between the LCD frame and tape, and slide outward while gently lifting up on the LCD.
Passo 4  ¶
Lift and remove the LCD from the iPad Mini. Lift and remove the LCD from the iPad Mini.
Passo 4  ¶
  • Lift and remove the LCD from the iPad Mini.
