Pular para o conteúdo principal
Ajuda
iPad 2 GSM Front Panel Replacement
Replace the front panel in your iPad 2 GSM.
  • Autor: Walter Galan
  • Tempo estimado: 1 - 2 horas
  • Dificuldade: Difícil
Note: this is a complete guide for replacing a plain front panel. If you have a Front Panel Assembly replacement part, stop before removing the home button from your old front panel, and reverse the steps to install your new front panel assembly.
Parts of this guide were shot with a Wi-Fi model and as such the internals may look slightly different from the cellular model. The procedure is the same for both models except where noted.
Passo 1 Front Panel  ¶
Front panel remains.
  • Front panel remains.
  • If you are replacing your panel with a new one, be aware that the new panel may have a protective film on the outside and/or inside of the frame. This needs to be removed.
